Hi @Eugenezh , what solved it for us was removing as much unnecessary frames and groups as possible. (see Gleb’s post from 1-feb)
If that doesn’t work, you could try splitting your work into more pages or different files.
Good luck
Good luck
This worked. Lagging gone.
I may be the odd one out.
But I am still experiencing severe Figma’s prototyping performance.
It still not only lags but crashes despite restarting my comp, the browser etc. As part of job application task I am demanded to work and present an array of design accross various screens. Simple as 99% of what everyone use Figma for. Yet it is a hog for some reason when viewing it under browser.
I have done many if not all of the work arounds here.
These performance slowdowns (at least in prototyping stages) used to be tolerable last year. But now ~ not even a scroll down 1/4 way of anything it chugs up everywhere. Chrome, Firefox, Safari included.
As I’m typing this, it’s getting worse! It is now stuck on the figma anim icon loading screen no matter what browser! And no matter how many restarts.
I have had 40+ hours worth of stake recorded in this project even if just a “trial” for a job application. If anyone can help me or at least experiencing the same, please let me know.
Same. No solution yet.
You can use an alternative way to show a presentation.
Try my Demo Station plugin to download your presentation as a ZIP-archive to show it even in offline mode. Or you can use the plugin to upload it into a cloud and show it.
I cannot even get simple form drop downs appearing nor working anymore in prototyping. Even if I cut and paste components to fresh new draft file with nothing else it still chugs up within Figma app itself, chrome and safari. Only instant state roll overs seem stable other than that, it’s macbook jet fan noise galore and browser crashes.
And this is without any fancy smart animate features by the way. Just linear on/off states.
Yes, Figma needs some fine tuning…
One Thing That is surely Work is steps i mention below will work for you maybe.
First thing you should more Focus is that i used figma in Chrome browser then i switched to it’s official app. It Great Works on desktop. Also Chrome browser use lots memory to run.
Second thing is If you are using Rulers in making Wireframes, Then it will definitely slow down process by half. I know Rulers are very important in Pixel Perfect Design, but when you need them most then you can use it, otherwise turn it off.
Third thing, if your design have lots of Images then use it by compressing via Plugin “Downside”.
My prototype starts lagging when i start a screenshare on zoom. It works fine for the first few mins but then the zoom cpu graph maxes out and the lag kicks in. I tried reinstalling zoom but it didn’t work. If i am not on zoom and dont screenshare, the prototype works from ne. This started happening a few days back and i am really frustrated as i have an important demo coming up in a few days. If anyone can help, please let me know. Thanks
I hope Figma is tracking FPS on user’s machines so they can identify the use-cases where performance is laggy. I’d happily let Figma spy on my projects if it meant they were gonna improve performance.
Also struggling with performance here, especially since my project is for a data entry system containing many interactive tables and busy displays.
Question - I’m trying to make it load faster and run smoother and have done ALL of the recommended optimisations already, but wondered which way to go on the following:
Any experience or knowledge of any of the above points would be really useful!
Local components: they are always loaded so they take up resources. External components are only loaded when you use an instance of them so if you use a library with 100 components and use only one component, only that one component will be loaded.
Fewer nodes = better. Doesn’t matter which type of nodes they are.
Few variants with hidden layers would be better since all variants are loaded at once when you use a single variant so if you have 20 buttons with 5 layers each, that’s 100 layers to load but if you have one button with 10 hidden layers that’s only 10 layers to load.
Shouldn’t matter for performance. But if you delete layers after detaching, that would be an improvement, e.g. if you have a complex instance with 100 nodes but only need 5 of them (others are hidden), then it might be better to detach. Detaching is not favorable though when you use components if it’s a long-term project which you are planning to maintain and update.
That’s amazing - thank you!
Also very glad to hear that I can create/use an external component library without it overloading every file that I link it to!
Would still be very interested to hear what effect variables and their various uses have on performance.
