I read all memory-reducing tips, but nothing helped. Could it help to publish library separate from the project ?
If your library is large and has lots of components and variants, then I would suggest you try splitting up your library across multiple files. Upgrading to a pro plan can help, since it allows you to create more than three files in your project, but if you are only using Figma for your own personal use rather than collaboration, the free plan should be enough, since you can create as many files as you want in your drafts. It’s hard to diagnose what could be causing memory issues, so if splitting up your library doesn’t work, I could take a look at your files to see if I can help figure out the issue.
