Its my first time using Figma, I used it to create a blueprint for a Prop I want to build.
Because I need to print it in Lifesize I used DinA4 sheets as background.
Now the problem is the sheets are empty, how do I get my Dessign to “stick” onto the DinA4 pages so I can export them one by one as PDF for printing?
Your frames will export blank because your design isn’t part of them (it’s not a child of the frames). You’ll have to copy the design into every frame. Simply Ctrl/⌘C your design and Ctrl/⌘V it into every frame. It should keep it’s original position within the frames.
Hi again. I want to come back to you and let you know about another feature that I overlooked. In the export settings of your frame, you can uncheck ignore overlapping layers to make the frames include anything that intersects them.
