How to pass <legend> from HTML to TS file?
I’ve figured out how to pass an input form to the TS file:
<p>
        <label for="receiverName">Name</label>
        <input type="text" id="receiverName" name="receiverName">
</p>
But when I try to pass the of a form containing that input, nothing happens.
<legend for="fromLabel" type="legend" id="fromLabel" name="fromLabel">From</legend>
I use the following script to pass the form data, which works wells for inputs.
    <script>
        document.getElementById('generate').onclick = (event) => {
            // Get the form
            let pluginForm = document.querySelector('#pluginForm')
            // Get the field data from the form
            let pluginFormData = new FormData(pluginForm)
            // Create an object and populate it with form data
            let formDataObj = {}
            for (let[key, value] of pluginFormData) {
                formDataObj[key] = value
            parent.postMessage({pluginMessage: {type: 'actionGenerate', formDataObj}}, '*')
    </script>
I suspect there’s something I need to change about the script. Anyone ran into this issue before?
Solved the issue :white_check_mark:
