How to create interactive component with instance swap icon?
Hello! I am a new convert from Adobe XD to Figma, and I’ve run into a couple things that I think should be possible but I have not been able to achieve them.
My app will have several little buttons that have the following parts:
  • Background color
  • Icon
  • Text
Upon tapping each button, the following should happen (within the button):
  • Background color changes to OFF state
  • Icon changes to OFF
  • Icon color changes to OFF
My goal is to create a component where the icon can be instance swapped, and that swap is reflected when the component is interacted with.
I’ve created a link here that illustrates my problem: https://www.figma.com/file/ZuT92N4vVhZeYcYZUpes0g/Instance-Swap-Prototype-Example?node-id=0%3A1
Thanks for your help!
Create a new instance swap property for the icon in the “State=Off” variant of the “Card / Scene” component. Let’s give it a name, for example, “Icon Hover”. Then select the instance of the “Card” component in the “Example” frame, change the “State” property, swap the icon, and change the state again.
Wow, thank you so much! Totally worked :slight_smile: Appreciate the help!
