How to add elements on top of responsive frames?
Hi there!
So I’ve been designing a website and came across one struggle :grimacing: How do I add elements such as icons on top of other frames/responsive elements of my website?
Using the screenshot example, how do I add these icons on top of my responsive table and make it centrally aligned to each of the columns?
Also using the second screenshot, how do I add these squares to the corners on top of the responsive container?
The second screenshot with the squares:
You can achieve these results using absolute positioning and constraints.
Oh yeah, it worked, thank you a lot!
But it seems there is a bug in Figma, because when I add these icons on top of my table and set the absolute position, it automatically adds the same shadow to my icon container as the table’s. When I go to the properties of the icon’s container, there’s no shadow in the properties.
Do you think it’s a bug or I am doing something wrong?
It’s not a bug if the shadow is applied to the top level frame. That’s why in my design I added another frame behind the table to act as the shadow caster. You’ll see it if you inspect my design file.
Got you! Cheers!
