Why shape size in autolayout parameters but x y is in position block? there is no sense in this. why is the thing responsible for the position, namely autolayout, placed next to the form?, and the position, which is more related to autolayout, is moved to another block?, when I want to change the size of the form, I now constantly look at the position, when the position is associated with autolayout, since autolayout is a setting that automates POSITION. Why don’t you place the position next to the autolayout, and move the layer size up?
you also have what is called constraints, and even the buttons for quickly distributing constraints are moved to the position, which is also related to autolayout, instead you create confusion by entering the layer size parameter in autolayout, which sets the position, and the position setting in another block. Why are you doing this? This is complete confusion …
