FigJam getting worse
The new need to click a shape every time you add a new block is objectively bad design. Adds a click to the vast majority use case where you don’t need to change the shape to reduce a click from the minority use case (when most people multi-select to change shape anyways, so even then it is adding clicks). Put it back please.
Also side note, the translucent templates thing when opening a new FigJam is annoying and I want to be able to never see that again. Slightly more forgivable because you can just carry on and it will disappear but it is useless at best and a distraction at worst.
