Figma Support Forum
Export window pane — can it be moved/rearranged?
I use the Export function a lot — it’s pretty annoying to have to scroll down to it every time though (not to mention having the “?” button covering it). Is there a way to move the Export pane to higher in the right toolbar? Or maybe rearrange the panes in general?
  1. You can hide ? button using Hide Help UI toggle in the search.
  2. If you already have export settings defined, use the File > Export… feature (faster with a shortcut).
Awesome thanks Gleb!
