If I add an image to figma and then resize that image I would like to export it at the original resolution. Maybe if there was even a button to resize the image to the full size.
**3. Ask questions to bring the community into the conversation ** (e.g. Does anyone else experience this? Is anyone using a plugin or workaround to help solve this?, etc.
I know a way how to export 100% scale image but it is not so easy.
Select a frame/rectangle with the background image and on the property panel set Image Fill type to “Tile” and next to it 100%. Then correct frame/rectangle size to fit only one image iteration. And export it as 1x.
If you want to see the original size of an image you can select the image, go to Fill, change it yo crop with 100% and you will see the actual size of the image.
