Figma support team sent those “fixing steps” to me as well, but they didn’t work at all.
" In the files where those issue is occurring, can you try the following steps: Select all layers Launch quick commands (cmd /) Search for and apply the option “Repair selected instances"
Now we are in the process of manually recreating our entire library and all the screens… which will take weeks.
…and in the meantime, other components continue to break (randomly).
Hello everyone ! Do you have any news about the cause of this bug? The quick fix with “Repaire selected instance” work well but we’re working on many huge files and it’s quite problematic… Thanks !
I placed a component instance from a library into a file I am working on and the component is empty. When I tested the same component in other files, it appears the way it is expected to. Additionally, when I click to go to the component’s master instance, it links accordingly.
@Josh@Figma@support I am also having this issue. This issue was triggered after I updated a component in the library—all of the updated components are now empty. I tried to update a second component, and have had the same issue. This “Accordion Header” was initially hidden with a “_” prefix, and I have tried removing that prefix to see if it updates in the file where it is used—it didn’t work.
The components are showing as completely empty—I cannot click into them to see their layers:
This issue is affecting a large number of components in our library. Instances are either entirely empty (they look like an empty bounding box, and the layers are missing), or missing entire parts of from layer structure when placed into a file. It doesn’t appear to affect new files, but I cannot find a fix for existing files that use components from the library. I’ve tried removing the problem components, unpublishing, republishing, etc. In addition, any new components added to the library since the initial onset of the bug will not work at all. I get an error message the component fails to place into the file. These components are now sitting in the updates modal and will not clear. I’m about to take the library behind the shed and start a new one because it’s totally debilitating.
Is this bug will be corrected in the next update ?
It’s the only workaround is to make a detach copy of the component and copy past it on all the screen we need to be seen. But we need a better solution.
Hi!
We are encountering the same issue occasionally. After modifying components in our design system library and publishing, these components simply disappear from other projects, or lose some of the content. It’s kinda problematic, because we’re a huge company, with hundreds of designers working on hundreds of projects.
Is this a known issue? Couldn’t find anything on existing topics.
We my team using our own design system library, in some pages the elements from the library cannot sync properly so that we have to republish the library over and over again…
