Editing states in instances DOES NOT WORK
Figma is starting to drive me insane, the amount of bugs is ridiculous, I usually find workarounds because I can’t wait for 6 months for something to get fixed, but I’VE HAD IT! You release some crap UI nobody likes, INSTEAD OF FIXING WHAT WE ARE ALREADY USING AND LOVING MOST OF TIHE TIME. Did Adobe infiltrate employees and they’re trying to sabotage you?
Why the hell of all hells can’t I edit a color in a variant of an instance of a component, without all the other variants of that instance to change that color? I mean it works sometimes, but not always. In the same instance of the component I mean, not in different components. Sometimes it might work, sometimes it doesn’t, sometimes some of the changes might work, sometimes none of them. And God forbid I try to change the stroke in a variant, that never works, all the strokes will be updated in all variants of that instance.
I feel like I’m playing cups and balls near the Eiffel tower with a bunch of gypsies. Maybe I’ll find the ball, but I usually won’t.
But meanwhile go ahead and try pushing that useless UI3 which everyone’s complaining about, ignore bugs, ignore everything else, try to justify some crap you did that cost a lot of money.
It seems to be working if I use HEX color codes, but it doesn’t if I use colors from the library (saved color styles).
So if I have Component A that has 2 states: default and hover. Default color is blue and hover color is red. In an instance I wanna make the default color pink and the hover color brown. If I use HEX color codes, it works. If I use colors text styles from my library, it doesn’t, both states simply get updated with the color I select.
hey, at least we can make some KICK ASS SLIDE DECKS… jk, it totally sucks
