Figma Support Forum
Drop Shadow doesn't respect layer alpha
When I apply the Drop Shadow or Inner Shadow effect on the raster image it does not respect the Alpha channel of that image. Alpha is set to cut-off in rendering shader instead of 8-bit.
Example:
Also, the same effects do not respect the resulting alpha channel of a blurred layer. For example if I add layer blur to the shape and wrap it twice in a component and apply drop shadow on the top-level component the resulting drop shadow will have incorrect alpha, inconsistent with content.
If you want to report a bug, you need to use the bug report form.
Yeah, I have. I wanted to raise awareness around that matter if the answer would be as usual: “as designed, not a bug”.
