Happened to me for the first time today and the reason was because I was connected to the wrong account on my list (I regularly switch between my business and private account). When I switched back to my other account it worked fine
Took me a while to realise it tho
We have noticed this was a memory issue, we got it to work by splitting out our library and publishing it solved the issue as the original file was too big to publish.
This suggestion, with a combination of finding the corrupted component - removing all instances, and recreating the component - fixed it for me. Thanks!!
My exact problem!
Icon library color edit. Now Figma pukes after 45 minutes attempting to publish.
If they won’t fix it the way you (Berkay) suggested then at least breakdown the publish packets to manageable bite sizes (Or bytes lol) from client side. AND pre check! Offer a solution before puking 45 minutes after a publish attempt. Selecting a few at a time to publish is not working either!
I don’t care if I have to publish 50 at a time at this point. I’m irritated beyond words right now. I have now lost one and a half days of productivity from the stupid icon color edit!
Figma, Please stop displacing blame and buck up. Just admit the poor implementation of publishing and merging, apologize, and Fix it.
I am finally seeing an exit back to Sketch because of publishing issues and merging headaches. Catch your market back.
Publishing by subsets will eventually work and help you to find out which subset is giving you problems. In my case, the publishing was failing because of the Paragraph styles. After inspecting everything the error was related to an update of a Paragraph Style I previously deleted so I unticked that box and all worked fine.
I have been experiencing this issue since June of 2022. It is super frustrating. The only solution is to publish 5 to 10 components at a time. This means publishing updates to 100 components takes me approximately 30 or more minutes each time as I need to batch updates into clumps of 10 with each batch taking between 2 to 5 minutes. Really expected them to resolve this by now.
There are a number of reasons publishing can fail, with the most common being that you may be running out of memory while publishing due to too many components in the Library, if there are empty Styles being published, or if one of the layers used in the file is corrupted in some way.
We’re glad that publishing updates in small batches works as a workaround, as this is usually the best solution.
Hey guys! I was having the same problem in the browser (Chrome). I even redesigned the two new components I wanted to publish and nothing happened. Same error: “Can’t publish while offline.” Tired of trying different things, I tried the last one: using the Figma App for MacOS. It worked! I could publish the new components to my library. I don’t know if this could help someone so I decided to comment my experience. Hope it helps
