I’m getting this error while trying to publish updates to a shared library:
Never had this error before, I thought it was a connection issue but apparently, it’s not. Maybe some corrupted component is causing it?
I’m getting the same error. Watching this question to see if a solution comes through.
From the few information that I could have on this recurring problem, we retain that the error is generally related to a corrupted component (it may contain a ghost layer, a union that contains nothing, …). The solution for some has been to remove components-to-sync from library one by one and try to publish each time to determine the infection. It’s a process that can be really painful if there are a lot of components.
So a simple way would be to contact customer support ⇢ support@figma.com
I tried publishing today and it worked. I have no idea what changed. I was trying to do the troubleshooting according to the instructions support gave me, and then it just published without problems.
This is one of those issues that seems to be coming up a lot, but there is no solid solution (that I have found). In my case it’s def holding up progress across our entire organization.
Here’s my current “publishing failed” details:
