Detach multiple components
Hi everyone,
I guess this can be solved quick.
I need to detach multiple components at once. Also components that are in groups or some hidden in layers. I know there was an easy way, but I just can’t find it anymore.
Thank you
Select the instances that you want to detach. Right click > detach instance.
If you want to detach every instance of the same component, then select an instance and bring up the ‘Quick actions’ menu
Then search for ‘Select all with same instance’. Then continue as above.
