Came here with this idea too. Would be very useful as designs constantly change. things move around and discussions often revolve around a specific element, section, etc. If I delete an element with a comment attached to it I think it would make sense to just have the comment unpinned.
I think the use cases vary. I would actually appreciate being able to pick between pinning a comment to an item vs adding a general comment vs a comment placed at a certain position in the frame.
Really do need this. And it’s strange because if an object is NOT in a frame, the comment will stick to it, but you can’t pin comments to objects in frames. But I can see an issues like a comment being pinned to a group and then the group being ungrouped later, so I realize this is a hard problem overall. Hope this can be figured out!
On a second level, have comment categories with view/ hide option.
For example,
I can create a wireframe design and me, or a collaborator, move it/ copy-paste it anywhere and comments stick with it.
Moreover, I want to create and distinct comments for the development team, separated from the comment to the CX team, other comments for the UX Writing and copies team, and instruction for UI team, so every team may be able to hide unnecessary comments and instructions/ help the async. communication between teams.
It’s extremely frustrating that comments do not follow elements on the stage. If the UI/UX of a mockup is rearranged it gets very confusing to follow the comment threads for further updates as comments are fixed elements.
Comments should be fixed relative to elements on your layers and not absolutely positioned.
If a layer with comments gets deleting it should prompt a dialog window to delete (or fix the position) the comments with the layer.
