Code block cannot set width programmatically?
cannot set code block programmatically with resize method
yes
Resize won’t work because height and width are readonly on the CodeBlockNode. The documentation is incorrect in saying to use a resize method instead for this specific node type.
Height is not resizable but width should be since it is the case manually so that’s a bug and it is very annoying in my use case.
