Is it possible to change one shape into another instantly? For example, I have a 10 x 10 rectangle that I want to convert into 10 x 10 circle by some selection process.
To do it instantly (and all at once by selecting multiple rectangles), and if you know a bit of TypeScript (or are willing to learn), your best bet is a plugin called Scripter.
Here’s a demo script where every rectangle you select is changed to a circle. Feel free to tweak it as you see it.
for (const node of figma.currentPage.selection) {
if (node.type === 'RECTANGLE') {
var circleDiameter = 0;
// This script will make a circle
// out of the rectangle's longest side
if (node.height >= node.width) {
circleDiameter = node.height;
} else {
circleDiameter = node.width;
// Create circle
var newCircle = figma.createEllipse();
newCircle.resize(circleDiameter, circleDiameter);
// Position circle at same origin as rectangle
newCircle.x = node.x;
newCircle.y = node.y;
// Copy the fills, strokes and effects
newCircle.fills = node.fills;
newCircle.strokes = node.strokes;
newCircle.strokeWeight = node.strokeWeight;
newCircle.effects = node.effects;
// Delete the original rectangle
node.remove();
I see. Yeah, I wanted to verify this wasn’t a built in feature. Thanks for the resource.
