I was trying to keep names of instances upon swapping, but it turns out for some reason it needs a delay before I can write a new name. Here is the code and the file for testing:
function delay(ms) {
return new Promise((resolve) => setTimeout(resolve, ms));
async function main() {
const comp1 = figma.root.findOne(
(n) => n.name === "Layer / Vector copy" && n.type === "COMPONENT"
const comp2 = figma.root.findOne(
(n) => n.name === "Layer / Vector" && n.type === "COMPONENT"
const instances = figma.root.findAll((n) => n.mainComponent === comp2);
for (var i = 0; i < instances.length; i++) {
const inst = instances[i];
const name = inst.name;
inst.mainComponent = comp1;
await delay(100) // comment this line to break renaming
inst.name = name;
const namesDifferent = inst.name !== name;
console.log(namesDifferent, "|", inst.name, name); // will be different
main().then(() => {
figma.closePlugin();
If I wait 100ms (very bad when processing lots of instances), renaming works fine: inst.name = name
sets the correct name and it’s printed in the console afterwards correctly. But if you don’t wait, the name change simply gets ignored and as a result instances don’t keep their names. I tried shortening the delay but it’s not reliable, works 50% of the time. I don’t think this happened before, at least I never had issues with this in the past and I’ve worked with instances renaming a lot.
