Can someone in Dev or Support share the Algorithm that produces the flexbox related CSS output?
This is to anyone in the know. But I bet this will need the involvement of @Figma_Support. Please assist if you can or pass on to Dev on Call to assist.
Could someone please share the algorithm here (be that in text description of the algorithm or pseudocode) so that I can correctly go from the JSON properties ‘layoutMode’, ‘primaryAxisAlignItems’, ‘counterAxisAlignItems’, and any others that factor into developing the following styles, to:
flex: none;
 (and? / or?)
display: flex;
flex-direction: row | column;
align-items: flex-start | center | flex-end;
 (or?)
align-content: normal | flex-start | center | flex-end;
justify-content: flex-start | center | flex-end;
<any others here>
I think I’m correct that flex-direction is controlled by Figma property layoutMode: HORIZONTAL | VERTICAL. Yes? But it seems a bit harder to be 100% sure how the other style values above are arrived at.
Are things like this already documented somewhere? I have looked but have not found it. Please advise if that is the case and I’ll happily look it up there.
Provided by someone on this community forum: A Complete Guide to Flexbox | CSS-Tricks - CSS-Tricks
That is helpful. But my question is not about the flexbox css et al. My question is regarding how to properly map from Figma’s internal plug-in or API properties to the CSS equivalents of the flexbox related styles displayed under Inspect > Code > CSS.
I am in the process of writing a programatic compliance check validator to ensure our programmers develop their UI page layouts and styles in full conformance to the design within Figma given to them by our Design Team. Therefore I’m going to the source, you, to ensure my algorithm accounts for all the conditions you account for in producing the flexbox relates styles.
Thank you,
Steve
Thru inspection of all configuration permutations of Auto Layout (all, that I care about at least) I believe I have the basis to form a complete algorithm. I also hope others find this helpful too, as much as I do. (it is a lot to get thru, I know. But, only because this is exactly how complex Auto Layout actually is! )
@Figma_Support , can you, or you get someone in development, to have a look at this?
  • Correct me if I got anything wrong.
  • And/or supplement if I missed any of the permutations.
  • Add any CSS name:value mappings I may have missed that are involved with Flexbox definitions from Auto Layout.
Much Thanx!
Here we go…
When FIGMA Auto Layout layoutMode === “HORIZONTAL” ::
FIGMA auto layout grid selection:
|_______________________________|_______________________________|_______________________________|
| primaryAxisAlignItems: MIN    | primaryAxisAlignItems: CENTER | primaryAxisAlignItems: MAX    |
| counterAxisAlignItems: MIN    | counterAxisAlignItems: MIN    | counterAxisAlignItems: MIN    |
| counterAxisAlignItems: CENTER | counterAxisAlignItems: CENTER | counterAxisAlignItems: CENTER |
| counterAxisAlignItems: MAX    | counterAxisAlignItems: MAX    | counterAxisAlignItems: MAX    |
Above Maps to CSS Below:
In All Cases when Auto Layout layoutMode === "HORIZONTAL" ::
 display: flex;
  flex-direction: row;
|_______________________________|___________________________|_____________________________|
|  align-items: flex-start;     |  align-items: flex-start; |  align-items: flex-start;   |
|  justify-content: flex-start; |  justify-content: center; |  justify-content: flex-end; |
|  align-items: center;         |  align-items: center;     |  align-items: center;       |
|  align-items: flex-end;       |  align-items: flex-end;   |  align-items: flex-end;     |
When FIGMA Auto Layout layoutMode === “VERTICAL” ::
| primaryAxisAlignItems: MIN    | primaryAxisAlignItems: MIN    | primaryAxisAlignItems: MIN    |
| counterAxisAlignItems: MIN    | counterAxisAlignItems: CENTER | counterAxisAlignItems: MAX    |
| primaryAxisAlignItems: CENTER | primaryAxisAlignItems: CENTER | primaryAxisAlignItems: CENTER |
| primaryAxisAlignItems: MAX    | primaryAxisAlignItems: MAX    | primaryAxisAlignItems: MAX    |
In All Cases when Auto Layout layoutMode === "VERTICAL" ::
   display: flex;
   flex-direction: column;
|_______________________________|______________________________|_______________________________|
|  align-items: flex-start;     |  align-items: center;        |  align-items: flex-end;       |
|  justify-content: flex-start; | justify-content: flex-start; |  justify-content: flex-start; |
|  justify-content: center;     | justify-content: center;     |  justify-content: center;     |
|  justify-content: flex-end;   | justify-content: flex-end;   |  justify-content: flex-end;   |
OVERRIDES to the above when using Advanced Layout:
1)  IF:  Spacing Mode === 'Space Between'
         So that JSON primaryAxisAlignItems === SPACE_BETWEEN
    THEN:
        justify-content: space-between
    ELSE, DEFAULT:
        Figma Spacing Mode === 'PACKED' and
        CSS justify-content value is defined by the tables above
FIGMA auto layout grid selection when layoutMode === “HORIZONTAL”::
|______________________________________|
| primaryAxisAlignItems: SPACE_BETWEEN |
Above maps to the following CSS ::
|  justify-content: space-between; |
FIGMA auto layout grid selection when layoutMode === “VERTICAL” ::
|______________________________________|______________________________________|______________________________________|
| primaryAxisAlignItems: SPACE_BETWEEN | primaryAxisAlignItems: SPACE_BETWEEN | primaryAxisAlignItems: SPACE_BETWEEN |
|________________________________|____________________________|______________________________|
|  align-items: baseline;        |  align-items: baseline;    |  align-items: baseline;      |
2)  IF:  Auto Layout layoutMode === "HORIZONTAL" AND Text baseline alignment is CHECKED
    THEN:
FIGMA auto layout grid selection ::
|_________________________________|_________________________________|_________________________________|
| counterAxisAlignItems: BASELINE | counterAxisAlignItems: BASELINE | counterAxisAlignItems: BASELINE |
|__________________________________|__________________________________|__________________________________|
|  justify-content: space-between; |  justify-content: space-between; |  justify-content: space-between; |
3) IF: Advanced Auto Layout Mode Both
        Spacing Mode === Space Between and
        Text Baseline Alignment is CHECKED
   THEN:
FIGMA auto layout grid selection when layoutMode === “HORIZONTAL” (mandatory for Baseline Alignment) ::
(no other combinations are possible)
@Figma_Support any update on this ??
