Can drawing pads be used in Figjam?
I like doing sketches or making mind maps roughly and simply using FigJam. But, I believe using the mouse is still stiff and less flexible. So, I’m curious, can FigJam use a drawing pad?
Hey @Fariz_Anshar – you should be able to use a tablet like Wacom with FigJam. Are you running into any issues when you try it? If so, what issues are you running into?
Hi Knishida, thanks for the answer. I’m actually curious about whether I can use a drawing pad for FigJam, because I have a plan to buy and use a drawing pad for my needs in FigJam. I’m worried if I bought it but can’t use it.
