Some of the text styles I had defined now appear to have broken links.
It has only happened to a few. Could it be the new update?
Got the same problem. Found that if you previously applied a text style and decide to resize a text field by using the numerical value on top right, it will reset and broke the link… If I scale the text field with a mouse drag, it will keep the text style.
I hope they will correct that problem, is support annoying, you can’t use mathematical formula for all text field.
Thank you Marc
