I’m trying to do something rather complex and about 90% sure it isn’t possible with the current autolayout options.
I have this modal design. The background is a rather unique shape. I want the background to adjust when the internal container (dashed for demo) changes in size. I’ve set that as a slot that I can replace with different content.
The interior section will need to be adjustable, but the spacing is 48,8,8,8. The modal
Here’s a proof of concept that I think covers your use case:
The main technique is hacky but I’ve used in production; it’s basically a fixed zero-height background anchored to the top right corner (with clip content turned off). The actual background is a component large enough to accommodate the widest size of your modal. (In theory, you could use an image for this background but it is not performant as an SVG).
Thanks @ntfromchicago for the help. The directions definitely solved my issue. It is hacky, but it’ll work for my master component. I was also able to put my header content in that top frame. So bonus!
