Hi Figma Support, I was collaborating on a file named "Prisoner App" (link below). I accidentally removed the person who originally owned the file, not realizing they were the owner. Now, the file is no longer visible to either of us — it doesn't appear in Trash, Drafts, or Projects, and we can't access it via the link. Here’s the file link:👉 https://www.figma.com/design/0pkPgS35mEJHzMnhZNWagr/Prisoner-App?node-id=0-1
Figma has been distant from users lately, and while I understand that they’re expanding their scope, the contact support button has become completely unresponsive. Here’s what happened: I transferred ownership of a file in a project from User A to User B, since B would now be managing it. B then removed A from the sharing settings and restricted access to invited users only. However, A still had access to the file and, assuming it was no longer needed, moved it to the trash. B was shocked to find the file was no longer accessible. When A tried to recover it from their trash, it wasn’t there. B also couldn’t find it in their trash. Now the file is gone — not visible in either A’s or B’s trash, and inaccessible to both. The question is: where is the file now? And I am here is community is because As i mentioned The contact support button doesn’t work. BTW although this ask seems chilled, I am losing my mind on where the file is because i have a deadline to meet.
Inputs are one of the most common UI design elements out there. But when you have to use them in a prototype there isn’t a good way to show what they look like when entering text. It’d also be great if we could trigger validation events like on a password input for example. This would bring more fidelity to my prototypes than just about anything.
For accessibility, I zoom in to my Figma UI to make text and icons easier to read, however, having done this, my Figma Make preview also does this. How can I prevent this from happening? Figma Design does not scale my canvases or content and I’d like Make to do the same.
Another day, another bug in Figma! 20 billion well spent adobe…Now my component’s which are in linked library’s are not updating correctly. I literally have to go into each component, make a edit by selecting another component state, and then Figma will pop up saying theres an update for this component - i select update ALL as i usually do, but its only updating the selected instance of the component. all other versions of the same component in the same page are not being update until I select them and do the same thing! what is this? what am i paying for? Frustration? a 2gb limit which make creating even a simple flow almost impossible? the limits of this thing are becoming as increasingly problematic as the bugs. Please fix it, also stop double charging for edits, when they are different teams, one person can only make one set of edits at one given time! criminal
Hi Figma team, I'm reaching out with a request on behalf of several developers on our team who use Linux as their primary development environment. Currently, the MCP (Multi-Context Preview) feature is locked behind the Figma desktop app, which is only available for macOS and Windows. This poses a challenge for Linux developers who are unable to access or use MCP due to the lack of a supported desktop app. We’d love to see one of the following: A Linux version of the Figma desktop app to unlock parity across development environments. An alternative way to run an MCP server without the desktop app, such as a standalone CLI or server binary that can be installed independently. This would greatly improve the development experience and make Figma’s workflow more accessible to cross-platform teams. Thanks for considering this request!
Please release an official version for the LINUX operating system because the version on github is unstable and outdated. Please think of your Linux users.
Hi, on a ComponentNode (inside a ComponentSetNode) the node property variantProperties has been deprecated (https://www.figma.com/plugin-docs/api/properties/nodes-variantproperties/) but is there no other way to get the active variant properties of a component node? The doc suggests use componentProperties instead but that node property does not exist on a component node inside a component set node.
The Problem When working on long artboards, particularly for mobile designs or landing pages, selecting the entire artboard is inefficient. If I am scrolled to the bottom of the page, I have to scroll all the way back to the top just to click the artboard's name/title. This breaks the design workflow for a very common action. Proposed Solution Allow a user to select an artboard from any point within its boundaries. A possible implementation could be: When the user hovers over an empty area of an artboard, its name (e.g., "iPhone 14 Pro - 1") appears as a clickable tooltip or overlay. Clicking this name would select the entire artboard frame. This provides a quick selection method without interfering with selecting other layers, as it would only appear over the artboard's empty background. Benefit This feature would significantly speed up workflow and reduce unnecessary scrolling, making the design process smoother for anyone working with long-format content.
I’ve lost access to my education account which holds all of my previous files. I thought I had linked everything to the account I’m currently on but it seems that no matter what I do, I cannot regain access to it nor the files.
Hi, everyone! I got a new phone, installed the Figma mobile app on it, and logged in, but every time I try to use the Mirror function, I get this error, saying Update or switch browsers. I tried everything, updated the browsers, switched between Opera and Chrome, logged in and out and nothing seemed to work. (My phone is Xiaomi Mi9 lite, with Android 10) Do you have any idea how to resolve this issue?
In the previous version i can able to paste the vectors as vectors from adobe illustrator but now it’s not working its getting pasted as image.. IS anyone facing the same issue??.. how to resolve this because that helps a lot
rename twitter to X
In my understanding of global components, when the Main component is made changes, it reflects in all instances automatically, but why is it that mine is not showing the changes?
Find answers, learn more.
