I have a nested component. Inside there are 21 components, and its height is 1073px. However, after I apply the Auto Layout, the height changes to 1073.02px. I checked all of the 21 components inside keep their height. Only some of them have Y position with .01 or .02 decimals.
I tried that. Yes, the parent component will be resized correctly, but the child components which got the Y position changed still has the decimal value.
And since I’m using Auto Layout, I cannot reposition them accordingly.
And thanks @tank666 for the fast replies and the plugins! Appreciate it. I tried them and still didn’t work. Then I did some digging and found out the cause of this problem. So allow me to explain my problem again and how I solved it.
My goal is to make a table-column that has minimum width, but is also resizable. So first, I created a table-cell component.
Since Figma doesn’t support min width, I created an “invisible” frame with 0 height. But Figma doesn’t support “0” input so I had to input “0.001”, so it’s rounded up to 0.
Turns out this work around costs me this problem. As the table-column consists of 20 cells, apparently the “invisible” frame’s height is still recorded as 0.001 in the backend and accumulates itself and affects the parent component.
So, what I did, was simply changed the height to 0.0000001 and it fixed!
