Alt-drag connectors results in duplicate placed directly above original
When alt-dragging a connector (that is connected to 2 objects), a duplicate connector is created directly above the original connector–which makes it appear as though no action occurred.
Yes, this behavior is reproducible:
  1. create a connector between 2 objects
  2. attempt to duplicate the connector by alt-dragging it
  3. expected behavior: new connector is created and follows the cursor
  4. actual behavior: new connector is created in exactly the same position as the original (pinned to the two objects)
Behavior seen on macOS desktop app version 99.7
macOS Big Sur 11.2.3
I realize that the duplicate connector is attached to the same vertices as the original connector–which results in them being positioned in exactly the same place.
I expected the duplicate connector to break free from the original connected objects and follow the cursor as I dragged.
I can duplicate a connector with 1 (or none) of its ends pinned to an object… though I did expect the connector (with 1 side pinned) to break free and follow the cursor.
Any solution to this? How to “ungroup”?
