Allow to enter emojis without typing words
  1. The new comment text box doesn’t allow to only type an emoji, you first need to go and type something in order to get the emoji icon appear to select an emoji
Who else experiences this? For me its very annoying cause I need to do an extra step to enter only 1 emoji
Hey @Melisa_Perrotta,
Are you using a macOS? If so, you can always use the emoji mac shortcut: Control + Command + Spacebar
Right now, when you want to reply to a comment with only an emoji you need to start typing something, then the emoji, and mention, icon appears and you can then select the emoji and also delete the text that you entered in order to view the emoji/mention icons.
  1. Add as much context as possible (screenshots, Figma files, mockups, etc.)
https://drive.google.com/drive/folders/1A9sKH2i5O5h9t1QUGCV-keD-JTTKdjZW?usp=sharing
  1. Ask questions to bring the community into the conversation
Thoughts?
