See the video below
Could you share a link to an example file?
Okay, I managed to recreate the same behavior, and I found several ways to solve this problem.
Method 1:
Add a “surface” instance to your component.
Method 2 (as in your example):
Wrap the “surface” instance in a frame with Auto Layout and set that frame to an absolute position.
thanks mate, method 2 works, much apprecitated!
the first one is under considiration, I want to add multiple accordion instances on top of the surface to form a card
Well, seems like wraping up the surface with auto layout frame is the way. I tried to add auto layout to the surface itself, however it does not work on component instance somehow
