Veneruso_Annie
Apr 22, 2025 8:13 PM UTC
Megathread preferred values and published vs hidden
The issue being faced today:
I want to have preferred values only show up under the instance swap feature. Not searchable in the assets panel, as these are typically sub-components that I don’t want to be used on their own (examples: a dropdown menu used in a global navigation component, the vector for an icon used to instance swap in an actual icon component to control the sizes via icon properties, a single segment used inside a donut chart, pre-configured links or buttons commonly used inside a bigger component to make it easier to select from a pre-set).
Why this isn’t possible:
  1. Unpublished and hidden components are treated the same in Figma.
  2. Hiding/unpublishing a component in Figma is currently the only way for it to not show up in the assets panel.
  3. Hiding/unpublishing a preferred value leads to additional issues:
    1. Preferred values cannot be selected by library consumers if they are unpublished.
    2. Preferred values must be published in order for updates to be available to library consumers.
The current workaround (that isn’t that great):
  • Leaving preferred values published which means consumers can grab unintended components for use from the assets panel, but this is necessary to continue receiving updates.
  • Or not use the preferred value feature in instance swaps, and relying more on creating additional variants with unpublished components that would have been a preferred value. And every time I need to update that component, I must publish, update, then unpublish the component again.
Related threads with this issue:
Apolline
Jun 2, 2025 2:08 PM UTC
I discovered this today, I totally thought hiding the component would mean it would still receive updates
Veneruso_Annie
Jun 2, 2025 4:00 PM UTC
Yeah, I think it’s because a hidden component is not published and only published components receive updates in other files. I don’t quite understand why this is the case, as there are times where having a component hidden from the Assets panel is necessary (you don’t want them to be searchable).
For example, any published components using hidden sub-components won’t receive updates unless the sub-component is also published 😓 Hoping Figma can change this someday
AntoinePuig
Oct 21, 2025 4:17 AM UTC
Yep, this would be great.
Currently, there is no way to streamline a component that has a lot of content variants without trade off:
  • Using preferred instances means building blocks need to be published and visible to consumers in a way that is usually not wanted.
  • Using surfaced properties from a nested component means no access to editing in a multiple selection
Having a big component with all variants remains the most user-friendly, but it’s heavy and annoying to maintain
Veneruso_Annie
Oct 21, 2025 5:58 PM UTC
We have a few big components, but another drawback is the load time. I believe what it tries to do is load in every variant of the main component so that switching between the properties is faster. But it can get very laggy to drag something like that into the file. A benefit of sub-components in the first place is being able to make those widespread changes in a single spot. And if it’s made of multiple sub-components that get swapped in, it will load in smaller chunks when actually needed, resulting in less upfront lag.
Hoping more attention can come to this thread, as properly supporting instance swap for sub-component use (which seems to be it’s primary function) and being able to select what nested properties are shown would go a long way.
Sasja Koning
Apr 14, 2026 12:52 PM UTC
Bumping this!
erin.io
May 14, 2026 3:55 PM UTC
Also bumping this as it’s an issue with slots. My example:
  • I have an Accordion component that has a preferred instance of Accordion Item for it’s slots
  • I have to publish Accordion Item in order for it to be available as a preferred instance, but I don’t want users to be able to add Accordion Item on it’s own directly from the assets panel
  • User searches assets panel for “accordion” and instead of just seeing the Accordion component, they also see the extra sub-components that they shouldn’t be adding directly.
Lewis_
May 19, 2026 3:04 PM UTC
This issue is significantly worsened for our Slots experiences!
Roman Vert
May 27, 2026 8:33 PM UTC
Double that. it’s very annoying and brings mess to the system.
Armin_Rouhanian
Jun 5, 2026 3:26 PM UTC
Ran in to the same problem with slots just now. I wanted to make a “Table” component and use slots and set “_Table Cell” as preferred component. I had one other problem that the slots couldn’t find my hidden component even though it was considered as preferred. To be fair, they showed me a warning that my inner component is not published and it should be. (should it really?)
I’m not sure if it’s feasible for Figma to detect these kind of components and do something about it. One way is that they add a new naming convention:
  • “Component Name”: Can be published normally
  • “_Component Name”: Are hidden and cannot be accessed or be used in “preferred” configuration
  • “~Component Name”: Cannot be accessed directly, but will be visible as an option in nested components and already been set as “preferred” (I couldn’t come up with better symbol)
It’s not an ideal solution though. I think Figma can somehow detect hidden component in the publishing process and threat them differently. Hope they find a solution for this soon.
Armin The Riverman
flauridsen
Oct 15, 2026 8:38 AM UTC
+1
Hide = Unpublish isn’t logical. It’s two different things and should be treated as such by Figma.
It’s crazy enough that they didn’t think this necessary for instance swap properties, but that it wasn’t introduced with slots either is wild to me. Not holding my breath for this seeing as there’s requests for this feature going back 3+ years, though...
