zb-sj
Apr 11, 2026 1:12 PM UTC
MCP get_design_context: Convert slash group separators to dashes in CSS custom property output
Context
With the Figma MCP server's `get_design_context` tool becoming a key part of design-to-code workflows, there's a friction point around how variable group separators are handled in CSS output.
Figma uses `/` to create variable groups (e.g., `blue/600` creates a `blue` folder containing `600`). This is great for organizing variables in the Figma UI. However, when the MCP generates code, the `/` is preserved literally in CSS custom property names: `--blue/600`.
The Problem
In Tailwind CSS — the default output framework for `get_design_context` — the `/` character is reserved as the opacity modifier delimiter:
bg-blue-500/75  →  background-color: rgb(59 130 246 / 0.75)
So when MCP output includes `bg-[var(--blue/600)]`, Tailwind's parser interprets `/600)]` as an opacity value, producing broken CSS.
The MCP works around this by escaping slashes as `\/`, but JavaScript consumes the backslash in normal strings. This forces every token reference into a `String.raw` template literal:
```jsx
// Current MCP output — unfamiliar pattern for most developers
<div className={String.raw`bg-[var(--blue\/600,#2563eb)]`} />
<div className={String.raw`rounded-[var(--radius\/full,999px)]`} />
vs. what it could be:
```jsx
// With dash conversion — clean, standard code
<div className="bg-[var(--blue-600,#2563eb)]" />
<div className="rounded-[var(--radius-full,999px)]" />
Why the MCP layer should handle this
The `/` is a Figma UI grouping mechanism, not a CSS naming convention. Every major design system converts group separators before CSS output:
Design System CSS Separator Example
Radix UI - `--gray-9`, `--blue-11`
Tailwind - `--primary`, `--muted-foreground`
Open Props - `--blue-6`, `--gray-9`
Material Designs - `--md-sys-color-primary`
Tokens Studio . → - (on export) `--blue-600`
W3C Design Tokens Spec . (ref) → - (CSS) `--blue-600`
Figma MCP (current) / `--blue/600` ⚠️
No major design system uses `/` in CSS custom property names.
Suggestion
When `get_design_context` generates CSS code, convert `/` in variable names to `-`.
The `clientFrameworks` parameter already collects framework information — if Tailwind-aware conversion isn't feasible for all cases, it could be applied conditionally when `tailwind` is reported.
Alternatively, when a variable has no Code Syntax override set, defaulting to dash-separated names instead of raw slashes would be a minimal, non-breaking improvement.
Current workaround
Setting Code Syntax per variable (manually or via community plugins like Syntaxer) does work, but it's opt-in per variable and easy to miss when new variables are added.
Related threads
- Ability to specify format of Variables Code Syntax
- Ignore variable group names
- Variables Web Code Syntax Bugs
