Mark Basa
Apr 23, 2026 11:26 PM UTC
Conditional dependencies between component properties
I’d like Figma components to support conditional/dependent properties inside the Properties panel.
Current problem:
Large design system components often expose many boolean, variant, text, slot, and instance-swap properties at the same time. Some of these properties depend on each other, but today they stay independent.
Example:
- If `Show Badges = false`, then `Slot Badges` should be hidden or disabled.
- If `State = Active`, then `New Message`, `Show Separator`, and `Swap Icon` could automatically switch to predefined values.
- If `Badge mode = Match`, then credential badges should be hidden automatically.
- If one badge group is enabled, another mutually exclusive badge group should be disabled.
Current workaround:
We have to create more variants, nested components, or expose multiple booleans manually. This works, but it makes component APIs noisy and allows invalid states.
Suggested feature:
Add simple conditional rules for component properties, for example:
- when property A = true, set property B = false
- when property A = false, hide/disable property B
- when State = Active, show properties X/Y/Z
- when Type = Match, hide Credential properties
- allow one parent property to control default values of several child properties
Why this matters:
This would make complex design system components cleaner, safer, and easier for designers to use. It would reduce invalid component states and make the Properties panel much less cluttered.
Stefan den Boer
Jul 31, 2026 9:56 AM UTC
Yes please!
