Color in part of instance is not controllable
Yuanrui_Li
As the Screen recording shows, I cannot change color in part of the instance, not matter if it’s linked to a variable, or detached. It can only be changed via its master component.
Best answer by Raphael_M
You need to re-union(merge) the path because there are 2 paths on your current vector file.
Current vector has 2 paths:
After union it will be merged into 1 path:
Yuanrui_Li
  • 6 replies
  • May 5, 2025
No one met this problem before? Or the screen recording doesn’t work? 🤔
Raphael_M
  • 394 replies
  • May 6, 2025
I have some guess, can you show the path? the entire vector layer? or send me a copy of the file just put it on drafts the share on view.
Yuanrui_Li
  • 6 replies
  • May 6, 2025
Thanks for replying! It’s a single flatten path. Please check the link attached
Raphael_M
  • 394 replies
  • May 6, 2025
Yuanrui_Li
  • 6 replies
  • May 6, 2025
thank you so much!
So it was not a single path. I wonder if it only can be distinguished through its code? It’s hard to find difference visually.
Raphael_M
  • 394 replies
  • May 6, 2025
To be honest, that’s not what is expected for Figma to behave. Because both colors uses the same variable so both should be modified simultaneously and not just that one path when you changed the variable, I’m just not sure what happened. You can try flagging this with the Figma team and see if it’s intended.
