Responsive web page with autolayout
Marina_Klimi
Hello, all, my name is Marina.
I am a graphic designer lives in Greece.
I have also background in web design.
The last year  decoded to transit to UX/UI Design.
I have finished the Google course and started getting into deep learning of Figma.
I have started with a web site for an African NGO that is called KIRC.
I have watched plenty of videos and tried to practice in “auto layout” and figure out how I can create a responsive web page.
I realised that there must be two ways :
Either create frames for different devices or create frames and component with “auto layout”.
Can you help me to clear this in my mind and follow a clear pat?
Here is the link of my web page:
https://www.figma.com/proto/teuNEmaEHMSHpSNIw03Kfx/KIRC?node-id=254-3350&t=hqI0fZMwJtzfLIc5-1
Have a nice day.
Marina
Best answer by Saquib Feroze
If You’ve Designed a Fully Responsive Frame Using Auto Layout:
  • It resizes for desktop, tablet, and mobile.
  • Spacing adjusts with percentage-based or dynamic values.
  • Elements reflow intelligently (like cards stacking, text wrapping).
  • It preserves proportions, shape, and hierarchy across screen sizes.
👉 Then you absolutely do not need to create multiple frames for different devices.
Focusing on:
  • Design efficiency
  • Scalability
  • Consistency
  • Saving time
This is what component-based, auto-layout-driven design systems (like Google’s Material Design or Shopify Polaris) rely on.
✅ When to Stick to Single Responsive Frame
Scenario Use One Responsive Design
Internal tools ✅ Yes
Dashboards / Web apps ✅ Yes
Email/newsletter templates ✅ Yes
Websites with minor layout changes ✅ Yes
Components and Design Systems ✅ Absolutely
You only need multiple sizes when the experience changes — not when the screen size does.
Since you've figured out how to make your layout fluid with auto layout, you're on the right path. There's no reason to duplicate work unless you're solving for a totally different user experience on a smaller screen.
sedatcakir
  • Active Member
  • 26 replies
  • May 13, 2025
Hello marina
Can you tell me what you want to do? I didn't quite understand you?
Marina_Klimi
  • 9 replies
  • May 13, 2025
Hello, I do not know if I managed with auto layout to create a responsive design.
Is it possible to have a responsive desktop frame?
Shall I concentrate on the templates design and manage the responsiveness when I will move to my  web site in my webserver where I will use WP Elementor?
I hope I was clear enough.
Greetings
Marina
sedatcakir
  • Active Member
  • 26 replies
  • May 14, 2025
Hello again,
There are problems with using auto-layout. At this point, you should organize your components well and assign the auto-layout feature.
Marina_Klimi
  • 9 replies
  • May 14, 2025
Thanks for your reply.
In order to understand there is problem with auto layout in my page?
I have watched plenty of videos before creating auto layout components.
Can you suggest me resources for responsive Figma web page?
Also how can I check the responsiveness of my Figma design?
Greetings
Marina
sedatcakir
  • Active Member
  • 26 replies
  • May 15, 2025
Hi again,
There are many videos on youtube. You can definitely find videos that meet your needs here.
If you need support on a specific topic, I can help.
Marina_Klimi
  • 9 replies
  • May 15, 2025
Thank you.
I will read again the resources and watch the video and come back.
Take care.
Marina
Marina_Klimi
  • 9 replies
  • May 16, 2025
Hello again I read the latest news of Figma 2025 and clear more the grid design system that is added to figma with the auto layout.
Having experience in web design tried to use the grid system to create responsive elements.
I tried to resize the frame and the most of the elements follow the size.
If you can also check it I will appreciate it.
Here is the link:
https://www.figma.com/proto/teuNEmaEHMSHpSNIw03Kfx/KIRC?page-id=423%3A4639&node-id=654-2986&viewport=-1602%2C-204%2C0.28&t=GTdBdSce3AG29dov-1&scaling=contain&content-scaling=responsive
Thanks
Marina
Marina_Klimi
  • 9 replies
  • May 16, 2025
The name of the correct frame is Home-responsive
Saquib Feroze
Focusing on:
  • Design efficiency
  • Scalability
  • Consistency
  • Saving time
Marina_Klimi
  • 9 replies
  • May 16, 2025
Thank you ever so much for all this inclusive information.
I will add it to my study guide and do another attempt for a responsive Figma frame.
Greetings
Marina
Marina_Klimi
  • 9 replies
  • May 25, 2025
Hello again.
I have studied the latest Figma 2025 Grid system.
Try to refresh my memory on CSS grid and I tried and I made another frame.
Could you have a look and let me know what do you think and if this is responsive.
Greetings
Marina
https://www.figma.com/design/mFOJrxota11cCjahjBk4Gv/Mkli-Portfolio?node-id=73-484&t=3YACUTo11uNMNC1y-1
Viji Design
  • May 26, 2025
If you're exploring responsive web page design with auto layout, I highly recommend checking out the approach used by Viji Design. As a leading company offering web design in Malta, their team specializes in building clean, fully responsive websites that adapt seamlessly across devices using modern layout systems like Flexbox and CSS Grid.
Their design strategy focuses on mobile-first development, ensuring user experience is optimized from the smallest screen up. Viji Design combines aesthetic appeal with performance by using auto layout techniques that dynamically adjust content spacing, alignment, and component scaling—crucial for today’s diverse device landscape.
If you're aiming for a website that not only looks great but also performs flawlessly across all screen sizes, Viji Design is a solid example of how professional web design in Malta is done right.
Marina_Klimi
  • 9 replies
  • May 29, 2025
Hello all and thank you for your replies but does not help me a lot.
I am a beginner and I would like to know if I got right the new grid system of Figma and created a responsive web elite.
I could not find something in .Viji Design this is a paid company does not have any resources.
Thanks anyway
Marina
Marina_Klimi
  • 9 replies
  • June 1, 2025
Marina_Klimi wrote:
Hello I would like to clear out that my above answer was not for all of you who replied but mainly for Viji Design.
Sorry if I caused any misunderstanding but the answers of
sedatcakir and
Saquib Feroze helped me a lot.
Greetings
Marina
Shobhit Aggarwal
If you're working on a responsive web page with autolayout, it's essential to have a solid development foundation that ensures your layout adapts smoothly across different screen sizes and devices. For those who may not want to build everything from scratch or need professional help, you might want to explore companies that specialize in responsive website development in Chicago.
One such company is Blackbull Technosoft. They offer responsive web solutions that use modern layout techniques like Flexbox, CSS Grid, and component-based design to ensure fluidity and performance across all platforms. Their experience in mobile-first development and performance optimization could be particularly helpful if your project requires a strong, scalable layout system.
Responsive autolayout isn’t just about making things fit—it’s about making sure the experience is seamless, and teams like theirs seem to prioritize that well.
