Resize components in a prototype
Ammar_Ahmed1
is there a way to create a figma prototype where you can resize components in prototype mode? i’m trying to resize components on drag (i.e. stretch navigation bar)
Armin_Rouhanian
Hey Ammar.
Yes, there is! In prototype interactions, there is an option called “on drag”.
You should design two states for your component, one collapsed and one expanded. then set the “on drag” prototype arrow. Make sure your animation is “smart animate”. Also, make sure your hierarchy of layers and naming in both states are the same. then, you’ll get what you want.
m.p
  • September 9, 2024
Is it possible to do that with a 3 states components?
I have a panel with 3 possible different layout according to the panel sizes, but I’m not sure how to get a nice transition/interaction
Ties
  • Active Member
  • 19 replies
  • January 21, 2025
Yes, you can. Figma will automatically pick what direction is the most logical for the state change. Let me cook an example for you tomorrow :)
Phu_Nguyen
  • Active Member
  • 44 replies
  • January 21, 2025
Just use On Drag & Smart Animate between 2 frames or 2 variants, here’s a demo:
Ties
  • Active Member
  • 19 replies
  • January 22, 2025
Volodymyr_Dziuman
Hi. Could you please share some file with this example. Thank you.
iago
  • 18 replies
  • February 20, 2025
this may help:
different task but same concept
Volodymyr_Dziuman
Thank you ​@iago !
Phu_Nguyen
  • Active Member
  • 44 replies
  • February 24, 2025
Hi this is the file:
https://www.figma.com/design/LwIyWxAuo53LngF9ndOMbb/On-Drag-Prototype?m=auto&t=y1VW4c6DpUn0i5In-1
