Prototype view settings when linking out from case study
  • February 21, 2023
  • 7 replies
  • 1635 views
Bronwyn1
Hi all
In my portfolio case study I have a link to a figma prototype / flow starting point with settings to view in desktop device.
My problem is the prototype opens up with some it cut off and the device off centre. If I close the side bar it rectifies.
When I am personally in Figma, playing my prototype I amn aware of the prototype settings - to hide side bar etc… which as far as I can tell has to be reset each time you view your prototype.
My problem: For visitors who don’t know figma - they are not going to know how to do this or bother to for that matter. It all opens up off centre which is not a very professional UX look when linking portfolio for job finding.
Any tips? Thanks πŸ™‚
Best answer by tank666
When you share a prototype link, make sure it includes the following parameters:
  • show-proto-sidebar=0 β€” hides the sidebar;
  • hotspot-hints=0 β€” disables hotspot hints;
  • hide-ui=1 β€” hides Figma UI.
These parameters must be listed with an ampersand. For example: &show-proto-sidebar=0&hotspot-hints=0&hide-ui=1.
tank666
  • 4873 replies
  • February 21, 2023
Bronwyn1
  • 10 replies
  • March 31, 2023
I am a bit delayed to reply but wanted to thank you @tank666 πŸ™‚
I never used ampersand before and you taught me something new. Thanks so much!!
Kidhack
  • 6 replies
  • August 3, 2024
how do you disable shortcuts with code?
tank666
  • 4873 replies
  • August 3, 2024
Am I understanding correctly that you want to disable shortcuts in Presentation mode using a query parameter? If so, then the following parameter is responsible for this feature: disable-default-keyboard-nav=1.
Kidhack
  • 6 replies
  • August 3, 2024
Awesome. Thanks. Is there Figma documentation for these strings?
tank666
  • 4873 replies
  • August 3, 2024
The feature is documented only for β€œHide UI”:
Figma Learn - Help Center
Kidhack
  • 6 replies
  • August 5, 2024
Strangely, β€œR” still resets the prototype with disable-default-keyboard-nav=1.
