Problem with managing image colour profiles
Manuel_B
I notice a strange behaviour in the management of image colour profiles. Some images with a Display P3 colour profile are displayed correctly, while others are converted to sRGB. This is a big problem; I cannot understand the logic with which Figma handles the images.
  • 3707 replies
  • July 23, 2024
Hey Manuel, welcome to the community!
You should be able to select your color profile settings modal, by choosing sRGB or Display p3 . (Usually, if you don’t have a preferred color profile set, then this legacy file will render in sRGB.)
To get information on how this works on Figma, I’d recommend your to check out this article:
Figma Learn - Help Center
Hope this helps!
Manuel_B
  • 4 replies
  • July 23, 2024
Hi Celine, thank you for the welcome.
I had already read that article, it explains very well the behaviour of Figma with Display P3 and sRGB colour profiles regarding graphic elements. Everything actually works as expected.
The problem remains with the images you import into your project, apparently they are mapped to sRGB even though they are Display P3. This, as you can imagine, creates major colour consistency problems. I have done various tests but they all lead to the same result, Figma does not seem to handle imported wide gamut images correctly.
I hope this limitation will be fixed soon.
  • 3707 replies
  • July 23, 2024
Thanks for your details feedback! Can you please also share some of the images that has that behaviour? That way, I can share it to our team.
Manuel_B
  • 4 replies
  • July 24, 2024
Sure, I’ll attach a screenshot. On the left a red 255 rectangle defined in the Display P3 colour space, on the right an image of the exact same red with an embedded Display P3 colour profile.
The colour should be the same but it is not, the image appears to be mapped in sRGB.
Obviously the screenshot is in Display P3 and must be viewed on a wide gamut monitor.
If I can be of any help on other tests let me know.
This is a problem we are experiencing with many of our customers using Figma and it is becoming very dangerous for the final output.
Thank you very much Celine
Manuel_B
  • 4 replies
  • July 24, 2024
Here’s the link of the original screenshot in Display P3 because the uploaded picture in the thread has been converted from the “forum platform”.
drive.google.com
  • 3707 replies
  • July 25, 2024
Thanks for the screenshot, I shared it to our internal team 🙂
Mark_Vogelaar1
@Celine_Figma Has there been a solution yet? Has been quite some time now. I am also experiencing these issues in Figma.
  • 3707 replies
  • November 18, 2024
Hi there! Our team would like to investigate it further. Can you please share the URL of the file here and share it to support-share@figma.com as an Editor, so they can take a closer look?
If you don’t prefer to share your file publicly here, please fill out this form by using your Figma email account: here. Thank you!
Manuel_B
  • 4 replies
  • November 19, 2024
Of course, this is the test project:
Figma – 4 Jul 24
I am doing it from my free personal account, I can share it in view-only.
Recreating the problem is very simple:
  1. Set the project with colour space Display P3
  2. Create a red colour box R=255 G=0 B=0
  3. Import an image with the same red values with built-in Display P3 colour profile (you can retrieve it from the link I provided in the project)
The boxes will be a different red. The box created in Figma is actually in the Display P3 colour space, the image is not.
  • 3707 replies
  • November 25, 2024
Hi there! Apologies for the delayed response. Thank you for sharing the file, our team was able to reproduce the issue.
We appreciate your patience as our team work on investigating it 🙏
