Pasting inside a mask, inside a component - can it be done elegantly?
Rebecca21
Hey Figma community 👋
Question: I have multiple layers in 1 frame, most of which are vector shapes. I have one specific area I want to mask so it can be reused numerous times across our team, if I make the whole frame a component though I seem to be unable to paste images into the mask.
Does anyone know why?
I have found a solution but I’m not sure it’s all that elegant 😬
The solution:
(1) Layers to frame
(2) Frame to component
(3) Select component from the assets panel, detach it, then paste it inside the mask.
This works but I feel it is breaking a lot of Figma conventions.
Keen to know if anyone has a better way. 🙏 😊
Best answer by tank666
Figma Learn - Help Center
tank666
Rebecca21
@tank666 Thank you for your response, I tried this but sadly didn’t work, the pasting object didn’t use the masking properties.
tank666
Could you show at least two examples of what such a component should look like? Also, do not forget to specify what exactly should be changed in it.
