Is it possible to import the AWS client SDK into a plugin?
  • April 11, 2024
  • 261 views
I’m trying to use @aws-sdk/client-s3 in my Figma Plugin to upload an exported page as a PNG, but I’m receiving a “Unexpected token .” in the console when running the plugin. I think this happens when trying to instantiate the S3 client.
I assumed because this package can be included in the browser, it would be possible to import this into my Figma plugin, but maybe my assumption is wrong.
Here’s my setup:
manifest.json
1{
2 "name": "",
3 "id": "",
4 "api": "1.0.0",
5 "main": "dist/code.js",
6 "capabilities": [],
7 "enableProposedApi": false,
8 "editorType": [
9 "figma"
10 ],
11 "networkAccess": {
12 "allowedDomains": [
13 "*"
14 ],
15 "reasoning": "Do what I want",
16 "devAllowedDomains": ["http://localhost:6069"]
17 },
18 "documentAccess": "dynamic-page"
19}
20
21
webpack.config.js
1const path = require('path');
2const webpack = require('webpack');
3
4module.exports = (env, argv) => ({
5 mode: argv.mode === 'production' ? 'production' : 'development',
6
7// This is necessary because Figma's 'eval' works differently than normal eval
8 devtool: argv.mode === 'production' ? false : 'inline-source-map',
9 entry: {
10 code: './src/code.ts' // This is the entry point for our plugin code.
11 },
12 module: {
13 rules: [
14 // Converts TypeScript code to JavaScript
15 {
16 test: /\.tsx?$/,
17 use: 'ts-loader',
18 exclude: /node_modules/,
19 },
20
21 ],
22 },
23 // Webpack tries these extensions for you if you omit the extension like "import './file'"
24 resolve: {
25 extensions: ['.ts', '.js'],
26 },
27 output: {
28 filename: '[name].js',
29 path: path.resolve(__dirname, 'dist'),
30 },
31});
32
tsconfig.json
1{
2 "compilerOptions": {
3 "target": "es6",
4 "lib": ["es6"],
5 "strict": true,
6 "typeRoots": [
7 "./node_modules/@types",
8 "./node_modules/@figma"
9 ],
10 "outDir": "./dist",
11 "allowJs": true,
12 "moduleResolution": "node",
13 "sourceMap": true
14 },
15 "include": ["src/**/*.ts"]
16}
17
src/code.jts
1import {S3} from '@aws-sdk/client-s3'
2
3(async () => {
4 const s3 = new S3()
5
6 ...
7
Luke Novak
  • March 17, 2025
+1
I know this thread is a year old but were you ever able to resolve this library? Other dependencies don’t seem to have this issue. Could use some guidance here from someone who has a little more experience building plugins.
