Input Field Textbox Variant Issue & Prototype Possibly Sizing Issue
  • April 11, 2024
  • 116 views
Please search for existing topics before posting! Press 🔍 at the upper right to search. Hi! I have an input field textbox with 5 different variants. I prototyped 4 interactions for the input field textbox, but only the first interaction will work. How can I fix this? I have also noticed that even though I used the desktop frame for my website prototype, when I am in presentation mode, I have to adjust the presentation to fit the screen. Do I need to rescale my frames and if so how do I do this? Thank you.
The link to my project is here https://www.figma.com/file/UttWo8Y81IkFoTlZZRDNra/Tutor-Connect?type=design&node-id=57%3A2982&mode=design&t=6cQnuxWZLA7Tw3Br-1
  • 2544 replies
  • April 12, 2024
Hi there,
Thanks for reaching out. After checking the prototype, it appears to be functioning with the variant as its setting. If this isn’t what you anticipated, could you please provide more details about your expected outcome?
In terms of the prototype size, you can set the device following the instructions in this article. Would you mind checking it out and giving it a try?
Figma Learn - Help Center
Thanks!
Toku
