Fixed to bottom disappears in prototype + vertical scroll not working
  • June 27, 2023
  • 903 views
Kashou
A few months ago, Figma decided to move scroll behaviors in prototype panel, and change the way they used to work.
  1. When I set a tabbar as “Fixed” to bottom, the tabbar disappears in prototype view. It appears only if I resize the mobile frame to real screen size.
    This means that engineer incorrectly implemented the “Fixed to bottom” behaviors as “position relative to top”.
  2. As a result, I can’t scroll vertical content if I resize screen to show tabbar…
“Vertical scroll” and “fixed to bottom” are incompatible since the update, can @Figma fix this asap? I reported the issue several months ago…
Proposed fix: tell engineer to implement “fixed to bottom” as “position relative to bottom”. That way, tabbar would be fixed to bottom regardless of screen size, and content would be scrollable vertically.
The same thing is happening to me right now, the old prototypes that were working properly are now screwed up and the new ones too. I hope we find a solution for this soon.
