Approaches to custom dark mode palette with a 3-tiered token system
Raz_Pulurian
I’m creating a design system with a light and dark mode using a standard 3-tiered token system: Core, Semantic, and Component. Each of these is a different variable collection.
On a previous project, I used a single mode on the Core collection with all of my colors (e.g., red-100, red-200, …, red-900) and created a light and dark mode on the Semantic collection that references the Core tokens. This was nice because I only needed to manage a single set of dark mode assignments on the Semantic layer.
On this project, I need to create a custom palette for dark mode with lower contrast and saturation.
My current approach is to create a light and dark mode on both the Core and Semantic collections.
Global Collection
Semantic Collection
This approach works with the following drawbacks:
Drawback 1: Displaying dark mode is a pain. I need to assign two variable modes (Core, Semantic) to display the dark mode colors.
Drawback 2: Editing Semantic colors is a pain. Dark mode values are not available for selection in the Semantic collection unless I have a layer selected on the canvas that has the dark mode assigned.
Drawback 3: When I close and re-open the variables window, it displays the light mode colors from the Core collection. What’s strange is that the component on the canvas displays the correct dark mode colors.
Has anyone experienced the same issues? Is there a more efficient way to set up a custom color palette for dark mode that allows me to assign a single mode to the layer and avoids these drawbacks?
One solution I thought of is to have a single collection called Theme with groups for Core, Semantic, and Component tokens. That would allow me to assign one variable mode and see the light and dark mode colors side by side.
Pavel_Kiselev
Have a look at the Souce Foundation colour system
It does not have many drawbacks, both light and dark modes are in the single collection.
Raz_Pulurian
  • 7 replies
  • May 5, 2024
Thanks @Pavel_Kiselev !
It looks like they did something similar to the solution I mentioned at the end of my post.
A single Theme collection with Core and Semantic tokens and two modes, and a single collection for Component tokens.
It does still have one drawback: I still need to have a layer with the dark mode theme selected on the canvas to assign the correct colors to the semantic tokens. But it does make the application of the Theme to a component much easier. I will give this a shot and see how I get along.
I’ll also need to talk to our devs about this to see if it works for them. In the meantime, still curious if there are other approaches people have tried, in case anyone else wants to share ideas.
Thanks again!
